last week, i noticed my coolant was very low. i filled it up, and last night i went to check everything before heading to RC later today and the container was empty again. i filled it back up...but i obviously have a leak of some kind. the car hasn't overheated, it only went up a bit last week and that was when i noticed it was low. oil is good, and no white smoke coming from my exhaust.
coolant issues
what vehicle?
I wouldn't be to scared to drive it just keep it topped off.
Keep an eye on the temp
sometimes you need a pressure pump to find leaks.
Sometimes they just leak under pressure and turns into steam so you never see a puddle.
Worst case it is a head gasket but they usually cause the coolant hoses to get very hard very quick.
If it a 2000 and up 4.0L open up the oil cap and look in when it is hot if you see green bubbles you have cracked head.
If you really need a ride I might be able to give you a ride.
~JustinRCrocs #123 Brown CJ-5
The 4.0L are known for cracking when the head cracks it just so happens to be right under the oil cap.
So if you open the cap in look in if you see green the head is cracked.
It might need to be hot to build a little pressure.
Coolant leaks are just one of those things that you need to clean it off and take a good look. Hose, Clamps, radiator water pump, etc. then the not so easy to figure out. Heater core, usually smell or steam when you put the heat on.
Heads are always tricky.
If the leak is slow enough you shouldn't have an issue.
I can take a quick look at Rausch.
Or bring it by the shop in Trumbull one night I work. (mon, wed)RCrocs #123 Brown CJ-5
hope it is not the radiator those are a royal pain on the V8s.RCrocs #123 Brown CJ-5
Originally posted by Lawn Guyland View Postit's the radiator
going to put a new one in this weekend
heh, you kiddin...radiator is WAY better than having to do some other things should be easy enough! just keep a gallon of coolant with you in case it gets too low. Grimace does the same thing except never loses it in the reservoir... just seems to magically evaporate, havent been able to find it yet...but once a week i put a couple splashes into the radiator and good for a week or so haha
-00 XJ. 3.5", 33s. Stuff
-Ian
if the forecast changes for saturday we'll be working on it at our house. come on by! i'll let you know what time we are gonna do it.Originally posted by hoggie101 View PostI work for food if you need helpmrs. heavymetal from jeepforum
