Originally posted by Hudson
Upgraded Wiring Harness?
Originally posted by ct67_72 View PostThey should all spin pretty easily. Sometimes you cant tell a PS pump is bad though until you have enough rpm to put a good load on it, but its worth checking by hand anyway
This time the belt began spinning. I don't even think it's the power steering pump anymore. It sounds more like something in the water pump area is making this noise.
I spun my new water pump by hand and it worked fine. I don't think that seized up THAT fast, but you never know.
Could i have made the idler pulley too tight or something along these lines?
Here is a video. Maybe you can understand this slightly better.
http://www.youtube.com/watch?v=Ft2cO...ature=youtu.beHudson
Originally posted by Hudson View PostJust went outside and started the jeep. The belt didn't spin at ALL when i first started it. I turned it off immediately after seeing that. Sprayed WD40 all over everything and started it up again.
http://www.youtube.com/watch?v=Ft2cO...ature=youtu.beOriginally posted by HitItWithSomeSpeeddidnt this thread start with Jon being gay? what happened to that?Originally posted by Lawn Guylandhe's still gay we've just moved on to more important issuesOriginally posted by Zullius Caesari grab dude's junk all the time, doesn't make me gay.
if the belt is cracking and catching you can try to save it by spraying belt tensioner on it. makes the belt last longer, but if it is catching bad enough to not spin, you are better off replacing it.
The inside of my YJ's engine bay was all black from me being to lazy to shut off the engine when spraying tensioner on. maybe that is why the alternator crapped out so quick
if your belt isnt spinning, chances are somethings locked up, take the belt off and try spinning the alternator pulley etc. should spin by hand. also make sure its routed correctly.up to 40% off parts from advance auto parts, buy online and pick up at store for free-click here!
as far as the wiring harness that you bought, i have the same one just waiting for a nice day to install it, along with other things that need to be installed. The putco harness is a good upgrade. the jeeps didnt come with the greatest lights to begin with and the fact that both lights draw their power from the switch makes the switch the short link. the harness gives each light its own ground wire, and a relay for both highs and low beams. I havent read or seen a single complaint about the harness except the supplied relays dying on some people. but they can easily be changed if youd rather not deal with risk.
http://www.naxja.net/forum/showthrea...dlight+harnessWhoever appeals to the law against his fellow man is either a fool or a coward. Whoever cannot take care of himself without that law is both. For a wounded man shall say to his assailant, "If I Live, I will kill you. If I Die, You are Forgiven." Such is the Rule of Honor.
Was going to quote everyone, but that'd be excessive. Thanks to every single one of you who inputted information.
I got the harness in, the new housings in, and the 60/55w bulbs in. My god. It's night and day. (Literally and figuratively.)
These lights work SO SO SO much better than stock. One of the best upgrades if not the best that i've done to the jeep. I can actually see things at night. These pictures do not do it justice.
Hell you can even run a 100/95w bulb in it if you really wanted to. I can't even imagine the amount of light that would throw off.
First picture is lows, second picture is highs.
Hudson
