Figured one of you might know more than me on this so i figured i might as well run it by you guys.
My dad has a 1997 Ford F-250 7.3. Every time he goes down a steep incline and the driver side tire gets most of the weight you hear a loud creaking noise.
I'm near positive it's the shock.
Anyways, does anyone have any recommendations on a shock for an f250? Should i buy him both shocks at once or just do the one that's bad?
Oh, and on a side related note. I have another question about my jeep.
It's about my T-Case. It's an NP242.
I thought that the reason the part time light remained on when in 2wd was because my linkage was messed up. I currently have no linkage (cut it out) and when i manually shift it into 4hi with an adjustable the full time light goes on. However, when i shift it back into 2wd the part time light remains on. What would cause this? I also couldn't shift into 4lo with the old linkage Should i be able to shift into 4lo with an adjustable wrench? Do i need to put the tranny in neutral? Either way the linkage is getting a rebuild. Hopefully something isn't messed up internally in the case.
