Hard Cold Weather Starts
  • Hard Cold Weather Starts
    my 94 yj 2.5fi is starting hard, temps at night have been 30ish
    what should i check first
    did you ever put plugs in that or no?
    -00 XJ. 3.5", 33s. Stuff
    -Ian
        bumping this post, it had nothing to do with temp, the jeep cranks fine ( new starter ) but takes about 1 minute of cranking to finally start, the check engine light comes on right as it begins to start, then shuts off, after it starts the jeep burbles for a few seconds, then runs PERFECT
        im going to do normal ignition stuff today, cap and rotor, check wires, and check some vacuum stuff
          Do you have access to a scanner with live data?
          If so check to see what the ecm is reading for coolant temp before you try and start it
          Dan.
            its a 94
            but yeah i had an obd2 key that hooks to my laptop to show live data
            i just did the cap and rotor, no change, also, spraying starter fluid down the intake yields no results
            im going to test the coil now, see if it shot
              hmmmm, you need a spark tester. So you can see what its doing while its cranking, maybe the spark is weak, wouldnt make sense that just all of a sudden it gets spark and starts though.
              Dan.
                yup, im waiting for my finace to get back so i have someone to turn the key, once shes here ill test spark and report back,
                i have the coil off, i was thinking of trying a different coil, i think i have a few accel and msd coils kicking around
                  IAC cleanse?
                    ill go check/clean it while im out there,
                      Ok, pulled tb , cleaned iac, also cleaned whatever sensor is in the intake manifold, unplugged computer, sprayed wd40 on connector, bolted back in
                      Now the jeep starts great, but i will see how it starts in morning
                        Nvm, went out and started it cold, took 1 minute of cranking to finally begin firing
                          found this
                          Well I think I finally found the problem but still haven't gotten around to fixing it yet. The jeep is my DD in the winter when it's crappy out and I couldn't take the chance of not having it for a couple of days. What I found was my fuel pressure at the rail is at about 80psi when running. It should only be 35ish. I changed the regulator and that didn't do anything. Basically what is going on when I first try to start the jeep the cylinders get flooded with massive amounts of fuel and has a hard time firing. What I've got is a pinched return line somewhere right around where the lines enter the tank. The skid plate looks kinda rusty so I wasn't sure how many days it would take for me to drop the tank and everything to inspect. So I should hopefully be getting to it soon since spring offically started yesterday. I will keep you posted on my findings!
                          check all the fuel lines
                            for the hell of it use a hair dryer to warm up your ECU next time its cold. I have seen that problem before.
                              This is it i believe , found out caps go bad imon ecm, 5 dollars at RadioShack to fix it, The jeep wont start until the CE comes on, then it fires perfect
