are there any known ignition problems with a 98 XJ? dads has been acting up really bad every 3-6 months....just dies randomly on the side of the road. dosent normally throw a code either. just happened about 45 minutes ago and i had to go rescue him. nothing seems to make a difference. cranks hard when it runs it runs real strong. definitely getting fuel as you can smell it after it cranks over for a bit. and no problems with lack of air. seems to be just an intermittent loss of spark. coil was replaced not too awful long ago. just curious about what is a common thing to go bad on the late models. im thinking crank sensor but it doesnt make sense because it only does it once in a blue moon. crank sensors when they go bad (from my past expirience) usually act worse and worse until they die. or is this just the beginning of a crank sensor issue?
known ignition problems?
-00 XJ. 3.5", 33s. Stuff
-Ian
"Blood makes you related, Loyalty makes you family"Tags: None
If i had one i might. seems after some tinkering today if you unplug and replug the ignition coil wire (incoming) not the actual plug wire that goes to the cap....it works fine....maybe a short in that wire...little too dark right now to work on it. tomorrow agenda.-00 XJ. 3.5", 33s. Stuff
-Ian
When my CPS started acting up, it did it very intermittently. It took about 3 months for the problem to progress to the point where it would stall out just about every time i went to drive it.Originally posted by 92xjlaredo View PostIf i had one i might. seems after some tinkering today if you unplug and replug the ignition coil wire (incoming) not the actual plug wire that goes to the cap....it works fine....maybe a short in that wire...little too dark right now to work on it. tomorrow agenda.
If you have one laying around (or even take the one from your jeep temporarily) toss it in and see if it helps.Hudson
Hmm not a bad idea....hadn't thought of that cause the jeep is parked for a while now. :/-00 XJ. 3.5", 33s. Stuff
-Ian
That should be the easiest way to rule out the CPS. What is wrong with your current Jeep? Is it still randomly stalling as well? Hopefully the CPS on that isn't shot as well.Originally posted by 92xjlaredo View PostHmm not a bad idea....hadn't thought of that cause the jeep is parked for a while now. :/
Oh, and some words of wisdom. The CPS is a fucking nightmare to get out. When you think you can't reach your arm any further, you're about 1/2 way there.
Get about 4 feet of extensions and a swivel socket, and lay with your feet facing the passenger door, and your head under like the middle of the jeep and look straight up. You should see it. Two bolts hold it on.
Goodluck. It took me like 20 minutes to find the CPS. It's hidden rather far up.Hudson
They arent that bad, gotta drop the front driveshaft. It took dizzy prolly 20-30 mins to do my first one and it took me about 45 to do my second one.Originally posted by Hudson View PostThat should be the easiest way to rule out the CPS. What is wrong with your current Jeep? Is it still randomly stalling as well? Hopefully the CPS on that isn't shot as well.
Goodluck. It took me like 20 minutes to find the CPS. It's hidden rather far up.-Caleb
i know right where it sits. and how to get there but yeah i do remember them being a pita....jeeps only parked cause i cant afford to drive it right now. still stalls out like a piece of shit but i think ive completely isolated it now. the distributor itself was loose and the cap was REALLY corroded for some reason.. cleaned it up, tightened it down and now the only thing that seems to affect the way it runs is the temperature sensor. unplug it, runs like a top. plug it back in runs like garbage...however its also parked cause i blew out a transmission line, front pinion seal is gushing, oil pan gasket and rear main are blown, needs a valve cover gasket really bad.....ive got a list of seals that come to almost 100 bucks lol-00 XJ. 3.5", 33s. Stuff
-Ian
