Originally posted by HeavyMetal
Anyways it hooks up to the radiator cap (they unscrew the rad cap and screw on this device) and they pump pressure into the system. If the system holds the pressure, you know that everything is sealed and that there are no leaks. If the pressure doesn't hold, you know you have a leak somewhere and the pressure really makes it obvious as to what's leaking. You can then replace the leaky/faulty part. However, i'm not even sure that a leak would cause no heat.
http://www.harborfreight.com/radiato...kit-65053.html
