What is the difference between a 6cyl ford 8.8 with 4.10's and a 8cyl ford 8.8 with 4.10's?
Ford 8.8
agreed, what's important is the spline count, brakes, and an open carrier with gear ratio you need. mine was a 2000 from i don't know what engine size. had discs 31 spline and an open 4:10. as far as i know engine size won't change as long as you're looking at EXPLORER axles. if you're looking at the 8.8 from a pickup or anything else then do some more research to be sure you get what you need.Hack Shack Racing #4632 Jeep TJ
Try searching therangerstation.com they have some good information there.RCrocs #123 Brown CJ-5
I read the rangers have different spline counts based off model and engine size. Also have seen that ALL explorers came with 31 spline shafts. I don't know how true that is.
Seems like one would just need to stay away from Ranger axles and you should end up with a 31 spline set up.
