So for the past two weeks I have been trying to diagnose this problem with my jeep. It started running weird. The idle started to vary and when I was driving at a steady speed and went to give it more throttle it had no response and lack of power. I could smell gas fumes. It seemed as it would catch up and I would have my power back. Then it threw a CEL. Po104. Which is the map sensor. So I changed that. Did nothing. Changed the o2 sensors seeing as they could throw that off to cause it and changes those did nothing as well. I started the jeep and sprayed carb clean looking for vacuum leaks etc. when I sprayed by the intake manifold it would cause it to run super shitty. So there's obviously a leak in the intake manifold gasket.
Do you think that the leak in the manifold would cause all of this? Idling funny, no power when on the throttle and has fumes?
Any advice and or suggestions would be greatly appreciated!
And don't say should have gotten a 4.0 mother fuckers
