Originally posted by Hudson
after you shut the engine it drops? that is normal if it drops too much it is usually the check valve but that just leads to long cranks to start.
when checking the fuel pressure. good trick is to pinch off the return line if it spikes the pump is definitely good if it is low when driving it could be the filter.
The timing light to check the spark is good when driving around just through it on the passenger floor if it stops flashing you lost your spark.
Some times you can position a spark plug so you can see it under the hood while cranking it is hard to do it yourself but it can be done.
you don't need the plug on it you can just stick a screw driver in the wire and hold it away from metal just a short cut.
Buy a manual you can figure out how to test everything. Most you can do with just an ohm meter graphing ones are just better.
