Sorry for all the threads, but the Jeep is currently enemy #1. I would of made the title more specific, but i honestly think this jeep is just falling apart, and in need of a lot of work.
Here is everything i'm experiencing;
- Random Stalling
- Jeep Not Going Over 3k RPMs
- Oil Pressure Is Higher Than Where It Used To Be (Used to always sit half way, now it's over.)
It used to be really hard to start, like i'd have to crank and crank and crank, and sometimes i'd even have to push down the gas pedal for it to start. About 2 weeks ago, it just died on the side of the road and wouldn't start at all, i had to let it sit for like 20 minutes, then it just turned over after some cranking. The new battery makes the engine turn over a lot faster, and i haven't experienced the hard starting yet after this.
The RPMs stop going up at 3,000. I can push the gas pedal all the way down, and it will NOT go over 3,000 RPMs. It just stops there. If i put it in park though, it will well exceed 3,000. I was trying to flex my front suspension, and i went to climb onto a rock, and my RPMs stopped at 3,000 and that was all she had. Didn't even make it up onto the rock, the RPMs just sat at 3,000 even though my foot was all the way down, it was like it wasn't even trying.
Some points after i drive it for like 5 minutes, it does this thing, where it feels like the jeeps rolls backwards while going forwards. That's the best i can explain it.
I think that might be my transmission slipping, and it need of a rebuild, but i could easily be wrong. It could also be the Torque Converter. If it is, it's a AW4 Transmission i believe. It's an Auto 99 XJ.
In the past two months, i have done this to it;
- New Oil
- New Oil Filter
- New Cap, Rotor, Plugs, Plug Wires
- New Battery
- Cleaned both grounds, and even rewired them. (Old one snapped, and i fixed it.)
I haven't tested any of the sensors, and my CEL isn't on.
I think these are mainly the culprit(s);
- Weak Fuel Pump
- Bad Coil
- Fuel Filter
- Bad CPS
- Dirty Injectors
- Possibly a slipping transmission
- Possibly a Torque Converter.
It's turning into one big headache, and costing me a fortune to try to troubleshoot.
- Random Stalling
- New Oil
- New Oil Filter
- New Battery
- Weak Fuel Pump
- Bad Coil
- Fuel Filter
- Bad CPS
- Dirty Injectors
