Temp Controller for fan?
  • Temp Controller for fan?
    just put a E Fan in my 2.5 yj, along with water pump and rad. runs awesome. i wired a relay to a lighted switch on the dash, but i would really like to automate it.
    does anyone know of a part store that carries a sensor that will engage my fan at a set temp?
    im not buying the 50 kit. so you need not mention that, it comes with wires, relays and so on.
    just looking for a fan controller. universal
    o0o and i might add, switching from solid stock fan ( locked with no clutch ) to this e fan. im running 150 temp instead of 210, and i have gobs more power.
    now i just need to get my neon injectors in !
    Need something off of a saab, vw, that screws into the rad. problem is finding a place for it.
    I run this, 23 bucks.
    http://www.summitracing.com/parts/HDA-3653/
      Yes it is just a temp switch you will need to find a coolant jacket or splice it into a hose.
      There is usually an extra port on the engine.
      you will need a guy that will work with you most guys just ask year make model etc.
      you can also get them from places like summitracing.
      http://www.summitracing.com/search/?...20switch&dds=1
      http://www.summitracing.com/search/?...0control&dds=1
      I don't know if I would trust a temp sensor in the radiator, you want to know the temp of the engine not the radiator.
        my sensor is a wet sensor, goes in the coolant
