3rd gear in my ax-5 done. ax-15 swap in a good idea?
  • 3rd gear in my ax-5 done. ax-15 swap in a good idea?
    So i'm driving along and i put in the clutch to put it in 3rd and i hear it grind. when i let go of the clutch and it grinds and it barely goes. all the other gears work.
    it's a 98 tj 4cyl with a ax-5.
    will i be doing any more damage if i continue to drive it? do i need a new tranny? swap in a ax-15?
    this is all new to me and i've never done any transmission work or anything close to it before
    well the ax-15 is way better transmission and it is a bolt together swap but sourcing the parts and I haven't done it yet so I don't know what issues you will run into like drive shaft lengths.
    I would check on the T-case the ax-5 might be 21 spline
    ax-15 came both 23 short and 23 long.
    ax-15 also came internal and external clutch slave
    also 2 different styles of pilot bearings.
    Also you will need a bellhousing from a s-10 or a dakota something like that cannot remember the jeep ax-15 bell housing will not work.
    you might also need a new clutch I don't know the spline count on the ax-5
    You should do some googleing and look for a step by step from someone who has done it.
    It will be a projected but can be done but not as easy as just throwing in a new transmission.
    Advance adapters might make a kit?
      will a yj's ax-5 bolt into a tj without doing anything to it?
      what ax-5's are bolt in for a 98 tj?
        You will need:
        An ax15
        A 6cyl t-case skid
        A 6 cyl np231 t case
        A 6 cyl drive shaft
        The tcases have different spline counts from ax5 to ax15 fyi
          I know for a fact that. 98 tj ax5 will bolt into a yj so i assume it would work the other way around
            thanks SO much for the info!! i've been having trouble finding a tj's ax5 for lower than $400 so was thinking about using a yj's
            for some reason yj's ax5's are all over craigs list but no tj's
              Just grab the external slave cylinder one. Forgot what year they changed over
