how fix small dent?
    Originally posted by justtorchit View Post
    yes just yes?
    almost every cage ive welded in a race car has been with the roof cut off.... im talking like atleast 10 cars.... weld the roof back on and cant tell.
    if you mean about "donig it right"... putting it on a "machine", they will do the same as you can with a prta pwer.
    The race cars im used to had fiberglass roofs and you just drill the rivets remove re rivet.
    But ya matt i would do a roof swap if you want it to clean looking still. Ill repaint the jeep for you.
    Dizz dizz go sleep sleep
      Originally posted by hoggie101 View Post
      Already planning for a full exo
      ew
        The roof swap is the easiest way to fix your completely butt-fucked A pillar.
          Just bend some more emt for a roll cage.............. its cheaper than dom.
              -54 Dodge Power wagon M-37
              -57 GMC Pickup
              -Tim (OIIIIIO)
                Id.like to live and be able to still drive my jeep when I roll it.
                97' zj
                2012 surbra imperza DD
                  Ouch i cant believe that rear window isnt shattered, if it was a woods truck i would get out the porta power and pinspoter , or just chop and cage it, but since its not it sounds like you already know what you have to do! Cut the roof and throw a new one on, and i think exo-xj's are sexy customjob
                    i still think this will just buff out............
                    -57 GMC Pickup
                    -Tim (OIIIIIO)
                      Just gotta use a bit of elbow grease...
                        I might do the first opition for a quick fix so I can get the cage in and then in the winter do it right so I can wheel this summer
                        97' zj
