When looking at axels in a junk yard are there any do or donts when making a selection. What differentiates a good axel from a bad axel?
Junk yard treasure
Really depends on what you plan on doing. Are you looking to re-gear? In that case just look for an axle with good shafts. Keep the stock brakes? Then look for one where at least all the parts were there.
When I got a new rear 44 I knew I wanted to regear, lock, and run disc brakes so I searched for an axle with shafts. Nothing else mattered to me at that point and found one with no brakes so I used that as a bargaining chip even though I didn't want them.
So whats your plans here?I don't always drink orange juice, but when I do, I prefer to chew it. #madpulp
Originally posted by ninetysix-ex-jay View PostCome on. Don't be a Will GentileNo worries, I'm not actually back, I'm just reminiscing about the old days.
4.10 HP30s are hard to come by. Keep an eye out, but as the time gets closer, you might end up having to get a HP housing cheaply and gearing it to 4.10. My roommate is going through this exact same thing with his TJ. Just finished welding the brackets on his 4.10 8.8.
Originally posted by clean4drxj View PostTheres alot of things to think about, what size tire do you wanna run(think ahead).97 XJ.
