Front Axle ID
  • Front Axle ID
    My tag is torn off on my front axle. I need to know what gear ratio i have in the front diff. I have a 1999 xj 5 speed. Its a Dana 30 High pinion ( i believe since the pinion is higher than the center of the diff) and i have a chrysler 8.25 rear end if that helps.
    I believe for a stick it should be a 3.07? help me out here. thanks.
    Nick
    shouls be 307
      god has blessed you with 3.07
      -54 Dodge Power wagon M-37
      -57 GMC Pickup
      -Tim (OIIIIIO)
        no tag on front axle???
        check rear axle tag..............
          exactly!
            no god hates you
            97' zj
            2012 surbra imperza DD
              Originally posted by hoggie101 View Post
              no god hates you
              haha you got me there
              -57 GMC Pickup
              -Tim (OIIIIIO)
                another interesting thing you can do is go to jeep.com - > contact us and request a build sheet. they will e-mail you a copy of the vehicle's build sheet listing all options it came with, color codes, ratios, etc . very handy to have
                  ill have to try that.. looked at the rear axle tag today, which also magically is ripped.. go figure.. All i could make out was 3.7.. could it be 3.73??
                    in all honesty if its wasted like that, and your jeep is stock...call corporate jeep, i actually had a similar situation where i was looking at an axle in a junkyard and i called them within 10 minutes the guy looked up the VIN and i had an axle ratio. its not a 100% gaurantee but youll know what that jeep started with.
                    -00 XJ. 3.5", 33s. Stuff
                    -Ian
