Prepping/ painting bare steel
  • Prepping/ painting bare steel
    Morning, I am ordering a set of atoz rockers, bare steel and wanted your opinion on what the best way would be to prep and paints to use. I was thinking maybe that por15 and then spray can bed liner .
    Thanks
    Don't Panic
    that sounds like it would be good, just make sure you prep the surface well or nothing will stick/ for long.
      Prime those babies like this
      Then use this
      I use a satin finish but it comes in gloss as well and you can get em at advanced auto on the post past the mall near walmart.
      Ive done tons of rattle can paint jobs and those lay down nice and smooth.
      ^pic of the spray head
      05 Black Rubicon
        It depends if you want a smooth finish or like the rough surface created from spray bedliner.
        05 Black Rubicon
          I like the epoxy paint idea, I'd prefer smoothe because the rough finish is a bitch to clean. Is that a special primer or just a basic out of a spray can. Did you use a gasket.
          Don't Panic
            VHT is one of the better spraybombs out there.. Primer, paint and liner the parts where you step.
              The VHT is awesome and very durable. I used it on a previous set of rockers I had and it held up great. As far as primer I used duplicolor filler primer I believe it was, nothing special. I am currently painting my Rokmen Rockers as well and will be using gaskets. Advanced auto has a great rattlecan selection, autozone sucks IMO. Good Luck!
              05 Black Rubicon
                Much obliged guys
                Don't Panic
                  Did you get a chance to go to advanced auto?
                  05 Black Rubicon
                    Rustoleum Automotive Primer. best shit made.
                    start with that and then move to whatever color you choose.
                    VHT is expensive so i only use that for certain things. I used to just use black gloss rustoleum on my rockers cause i could wheel, scrap em up, powerwash it, then spray another coat in the spots that were scrapped. Always matched well and prevented it from looking like garbage. haha.
