setup bearings
  • setup bearings
    does anyone have any setup bearings for a dana 44 that i could borrow? i need to set up my diffs and don't really feel like grinding out some old ones or ordering a set for 60 bucks
    took me about 10 minutes to grind out a pair with a dremel with 3 cut of wheels on it (didnt have grinding wheels)
    just did this a couple days ago. i could bring em' to the meet and greet for ya if thats soon enough
      maybe i'll try to grind out my old ones if it only takes ten mins... i'll let you know if i need them at the m&g. thanks sam
        yea alll it takes is a very little bit of metal ground off. i just made a bunch of quick passes til i was all the way around the bearing about 3 times
          FYI used bearings are usually more worn than new bearings and if you set up the thing with the used ones and then throw the new ones in you might get fucked.
            Ive had good luck with setups bearings. My d60 set is new, and my d44 set is used, both have given me nice patterns in the end
            1950 Willys Trail Rig
