Yesterday the abs pump on my 90 Cherokee ran for ten minutes straight. The sputtered and stopped. Brake light came on and my pedal is xtremely hard then it goes to the floor. Jeep barely stops. Anybody run into this issue before. This is my only car and need it not loosing brake fluid or anything either..
renix abs/brake issues
Originally posted by Hydra View Postif it ran and ran the fluid had to be going somewhere. either a leak at a wheel, or your pump burned up and the heat boiled away your brake fluid.Originally posted by Buffalo Phil View PostMy pedal went all the way to the floor once on the highway due to a bad brake line pissing fluid all over the place. Foot to the Floor means loss of pressure, check for leaks.Dizz dizz go sleep sleep
Have never had the ABS part happen but something got into the system on my Dakota and killed some seals in the MC. The pedal was hard until you slowly pushed the pedal. Your foot would go to the floor when you slowly push the pedal. I quick pump would stop the truck but not a slow push like you would under normal braking.Molten Motorsports - #4343/4443
exact thing happened to me dude. There's this crazy high pressure vaccuum ball thing that always goes bad. I cut my losses with that bullshit system and picked up a 96 master cyl, booster and prop valve. Made a huge improvement in braking power, and pretty much bolted right in.1993 XJ sport 3.5" rustys 33" MTZ's armored.
Originally posted by wannabejeep View Postexact thing happened to me dude. There's this crazy high pressure vaccuum ball thing that always goes bad. I cut my losses with that bullshit system and picked up a 96 master cyl, booster and prop valve. Made a huge improvement in braking power, and pretty much bolted right in.-Caleb
