how should i go about removing this, or should i just round the corners and leave it on the axle?
spring perch removal
I found this today while ordering my tnt truss, you do have to cut back that perch.
HP 44 & Waggy 44 leaf sprung will require removal of Passenger Side leaf spring pad, shock
mounts, trackbar mounts. Trimming of Drivers side spring perch and casting for proper truss
clearance is required as well. Truss placement requires 2 3/8” of the driver’s side casting to be
cut off completely around the axle. Strength of the axle is unaffected due to the addition of the
truss.
