Just picked up a 98 xj 5 spd with 108 on the clock. It needs a clutch, i have never done one before so i am wondering if there are any suggestions on parts or how to go about doing it. Thanks guys!
CLutch in 98 xj
If the new clutch didn't come with it you'll need a clutch alignment tool which is cheap. Other then that its really not a hard job but time consuming. Not sure on an XJ but on a TJ we had the engine and trans out anyway so we did the clutch while we were in thereI don't always drink orange juice, but when I do, I prefer to chew it. #madpulp
get a Luk brand clutch kit. its oem and holds up well
im assuming xj use's an ax-15 also. if so its not to bad, theres some writeups online. if you have access to a lift (shop) its super simple) if not you can do it in your driveway just a little more difficult.
most of the time people recommend machining flywheel or replacing but i honestly never had a problem with the flywheel on a jeep unless it was contaminated with something.up to 40% off parts from advance auto parts, buy online and pick up at store for free-click here!
Originally posted by 1cleantj View Postget a Luk brand clutch kit. its oem and holds up well
Personally I would just do it while I was in there. Do these year Jeeps have slave cylinders? I would at least check the slave while in thereI don't always drink orange juice, but when I do, I prefer to chew it. #madpulp
Ya I'm going to check it out if the jeep has
A slave cylinder could it just be that. The car jerks when u let the clutch out and I'm surprised the clutch went cuz I knew the previous owner and they have been driving a stickfor along time-98 XJ 4.5" lift , 35's, trimmed, locked, geared, flexy
-54 Dodge Power wagon M-37
-57 GMC Pickup
-Tim (OIIIIIO)
all the clutch kits i've used came with alignment tools, don't think I've ever used them though, it's been a while1992 xj Briarwood
Welded front and rear
13' LED roof lights
Disco ball
Truck nuts
Spinners
