So, last night i went to use Dana's lincoln 175 to weld my rear end. (barrowed it to weld a 44 up and worked like a charm.) well i got it set up, put a spool of wire in it, got the wire fed through to the gun, and i get under teh jeep and ready to melt metal. (i turned the wire speed all the way up to feed it faster, then turned it back down) pull the trigger and the wire wont feed. take it apart and the wire feed motor is not spinning. the trigger is working as u can hear the relay and gas still kick in.
anyone know of any common problems with these welders? im figureing its something between the potentiometer, circuit board, or motor. (hard time believing its the motor) all wiring conections are good. im going to take a reading from teh potentiometer tonight to see if the resistance is broken.
where is teh best place to get replacement parts for these? or should i just bring it to the pros to fix?
