New JKS shock mounts damaged?
  • New JKS shock mounts damaged?
    tried to search but i couldnt find much.i just for my JKS shock mounts in the mail, the front upper ones that eliminate the "stem" type shocks.. but they look bent/warped to me..
    here is a pic of the same mounts i found via google images..
    so is this how they come from JKS or are mine damaged?
    Did you buy these off ebay? If so id be worried.
      4wd.com
        Originally posted by lilnapsak View Post
        4wd.com
        there are two diff models, you need the other ones.
          one is for XJs the other is for YJs (i think)
          either way caleb is right, there are 2 models. i cant recall if mine are like that or not, but i have the same mounts
          for some reason i wanna say mine are what you have. i will go check.
            What you have
            http://store.jksmfg.com/merchant2/me...ory_Code=Shock
            What you need
              These are the same ones I have with the bend in them but I also have a 96. There's nothing wrong with them.
                thanks.
                  now go get some damn fox shox you betsy and stop messing around on naxja tech askin about 5150s
                    that was for the REAR.
                    ive got a box full of shiny expensive on on its way
                      yj ones have a ten degree tweek to them. thats what you have there sir.
                      Dizz dizz go sleep sleep
                        sounds like your style
                          youll have a good look at it when i fly past you on the trails
                            5150s cause 9/11
                              There was no Reason for you to go out and make such a purchase in the first place. The Jeep engineers designed your shock mounts to such exacting specifications that they should never need replacing.
                              If you ask me, that's what happens when you start trying to fix things that weren't broken in the first place. So many companies are willing you part you from your money with "snake-oil". If you buy into it, it's your own fault and I refuse to feel sorry for you.
                              Save lives; Please keep your Jeep stock
