got a 2.5l tj here. the upper hose is sucked shut almost flat like. the other day i went to drive it to see what was up with it cause the customer complained of it being sluggish and over heating. anything to do with the head gasket. its got new plugs wires cap rotor on it, i think someone was chasing a miss fire. any thoughts on this would be greatly appreciated.
rad hose sucked shut
hose is spongy gonna replace it no matter what rad is new water pump is new t stat is new. the cap was clogged with rust though. i'm assuming when they did the work they didnt flush the block oout like u should.Originally posted by Bigbike View PostHrmm, Ive normally had the lower hose get sucked shut due to the waterpump. Is anything clogged?Dizz dizz go sleep sleep
X2 I did a heater core with my buddy in his garage...5+ hours later it was done but just about every plastic tab was broke off lolOriginally posted by clean4drxj View Postmost jeeps are PITA's if your dealing with interior problems(behind the dash) or under the hood.. NO f-in room!
-00 XJ. 3.5", 33s. Stuff
-Ian
