welding spiders
  • welding spiders
    I don't want to hear about welding your spiders is a bad idea, i know plenty of people personally that have daily driven welded gears and never had a problem.
    In the near future i'll be getting 5.13's with a spool for the rear. But until then i'll be sitting on the stock (what i was told) 3.55's. I know once i finish my swap i'm going to get the itch to go test it out once or twice, and i would at least like to have 1 locked axle(obviously the 60).
    My main concern is doing this with my arc welder. Like i said i see people with welded spiders all the time but most of the time they are using a mig welder. I don't know very much about welding so is this a bad idea or should i just go for it. Worst case scenario my spiders explode and the jeep sits in my driveway with FWD until gears come.
    slag. case. no no. eberytimg else a go-go.
      Arc welding is actually probably a better idea than a 110 mig. Get a couple of cans of brake cleaner
        36's and 3.55's
        oh wait thats what you have now
          i would assume that the iroks are going to melt with a spool in the rear.
          sam are your wearing fast with a spool?
            i have driven it like 1000 miles with the iroks (if that)
            its been in and out of brokenness all winter.
            but generally tires melt and i have the turning radius of a school bus
            my tsl's went from full tread to half tread in like a month and half
              corey did this to my 8.25.
              worked good, but i was on 33's.
                Holy shit what a waste of wire, what was I thinking when I used that much wire?
                  holy weld batman.
                    Shit's built.
                      "i'm going to use a lot of wire"
                        Hey rockymountain, if you can arc weld MIG is a piece of cake
                            I'm confident i can weld it, but i'm afraid like fred said about slag now.
                              Some pretty good tech in this post from Pirate4x4 about welding spiders.....
                              http://www.pirate4x4.com/forum/showt...welded+spiders
                              - 99TJ 4.0 4.5 RE springs, Clayton 5in LA stretch, GenRight Armor, 35x12.50 bfg mt, currie hp9 rear w/ 35 spline detroit, hp44 w/ arb and 4340 axles, k/n fipk, banks headers, warn xd9000i
