xj recovery points
  • xj recovery points
    need some ideas since i have none and oer is right around the corner let me see what you did for them
    thank you
    97' zj
    2012 surbra imperza DD
    Stock bumpers? what have you beefed up around the body?
      get yourself a trailer hitch and put a shackle recevier in it and get some towhooks w/brackets for the front or if you can swing it a good front bumper.
        You could just go all hick life and wrap a chain(must be a chain) on the inside of the bumper around the mounts. Seen this done 3 times and make me lol every time. If you enjoy constant large metallic clanging sounds and death while attempting to recover than this recovery method is for you.
        But really clean4drxj's idea is a good one but in terms of time you can just pick up those little hooks that tie into frame rails, the are just hooks so they kind of suck but still they are cheap and easy to install.
        Eric
          Hitch in back, d30 up front
            Autozone carry's a hitch that will work for like $120. When I had it on mine I flipped it and cut out the bumper so it sat a little higher, which would only work with one of those cheaper hitches that slide to fit different vehicles. But, if your really worried that seems like the best bet, You can have it in today.
              Trailer hitch is good for the rear and towhooks for the front are the cheapest and easiest ways to go.
                advance auto parts carries bolt on tow hooks (10,000 lb rating) for $10.40 a piece retail
                receiver hitch in rear - $120 retail
                reciever hitch tow ring - $47
                $187 + tax retail
                -OR- if you order online with free instore pickup
                it will cost you $137+tax (use discount code VISA )
                OR just order 4 tow hooks for 41.56 + tax (order online using discount code BIG15 and it will only be 26.56 + tax
                for a cheap fix, 4 reese 10,000 lb tow hooks for $26.56 + tax would be my option. even if you spent a little extra money on some Square/rectangle tubing to beef up unibody rails it would still be cheap
                  The autozone by me has receiver d ring things for $20. same thing I paid 21+ shipping from quadratec. and since its a cherokee with a unibody tow hooks from advanced are kinda out unless you order/make brackets.
                    fronts done i juat order tow hooks and brackets for 75 dollars so thatll get me though oer and then ill get a bumper and then the back ill do some getto shit for the three days
                    97' zj
                      not hard to make though, add reinforment plates to side of unibody rail near tow hook and double up using stock bumper mounts.
