Whats the bare minimum that needs to happen to convert a dirt bike to street legal?
Dirt Bike to Street Legal?
Originally posted by Capt. Crunch View PostWhats the bare minimum that needs to happen to convert a dirt bike to street legal?
Definition - Motorcycle
According to Connecticut General Statute 14-1, www.cga.ct.gov
"Motorcycle" means a motor vehicle, with or without a sidecar, having not more than three wheels in contact with the ground and a saddle or seat on which the rider sits or a platform on which the rider stands and includes bicycles having a motor attached, except 'bicycles' propelled by means of a helper motor as defined in Connecticut General Statute 14-1, but does not include a vehicle having a completely or partially enclosed driver's seat and a motor which is not in the enclosed area.
Handle Bars
Motorcycle handle bars are to be no higher than the operator's shoulders.
Odometer/speedometer
Required.
Drive chain
A chain-guard is required.
Registration
Motorcycles are required to display one number plate at the rear.
Headlight
Each motorcycle shall be equipped with at least one, but not more than two, headlamps. Either the single or multi-beam type light shall be permissible.
Tail light/stop light
At least one red tail-lamp and one stop light are required. The rear number plate must be illuminated with a white light.
Brakes
Each motorcycle and motorcycle with sidecar shall be provided with at least one brake. Motorcycles designated as 1974 or later models shall be equipped with brakes on the front and rear wheels, excluding wheel(s) of a sidecar.
Original Vehicle Identification Number
This must be cleaned so that it can be checked by the Inspector. A new Connecticut identification number may be assigned if appropriate.
Note: All composite motorcycle inspections are done at the Wethersfield inspection lane from 8 a.m. to 3 p.m.
dana pretty much covered it, blinkers are optional , but then you would need to use hand signals.
Digital odometer/speedometer is easiest way to gain those things
if your dirtbike already has a headlight, adding a LED tail light would be your best bet to keep your bike charging if its electric start. unless you got a tail light already
cheap led turn signals would be nice also.
DOT legal tires for inspection.
here is a street legal enduro (my bike) for reference. these tires would not pass inspection though.
Last edited by 1cleantj; 07-06-2011, 06:50 PM.up to 40% off parts from advance auto parts, buy online and pick up at store for free-click here!
