I Installed sye on tj and got TW cv style shaft I set my Pinion angle up to what i think is correct aaccording to what ive read but im guessing its not because im getting vibes. Was wondering if any one on here knows how to set it correctly and can come give me a hand getting this set up correctly. Let me know.
adjusting pinion angle help
Originally posted by JeepBabiiXJ View Postdo you have adjustable rear upper control arms?01 tj
easiest way is to get a digital angle gauge, you can get a pretty good spot if you have the diff cover off, just place the gauge on the face of the centersection (where the diff cover bolts to) and set the gauge to zero. Leave the driveshaft connected to the rear end, then put the angle gauge on the driveshaft itself, use a bottle jack under the pinion to bring the gauge to 90 degrees.No worries, I'm not actually back, I'm just reminiscing about the old days.
Originally posted by JeepBabiiXJ View Posteasiest way is to get a digital angle gauge, you can get a pretty good spot if you have the diff cover off, just place the gauge on the face of the centersection (where the diff cover bolts to) and set the gauge to zero. Leave the driveshaft connected to the rear end, then put the angle gauge on the driveshaft itself, use a bottle jack under the pinion to bring the gauge to 90 degrees.01 tj
