I have a 98 tj with a 2.5L with about 107,000 miles. I give her full synthetic oil changes about every 5,000 miles or so. Doesn't leak a drop of oil and never had a problem.
Today i hear a knocking from the engine and it gets faster as i hit the gas and she's burning oil and blowing white smoke from the exhaust.
Blown ring? cracked piston? is there any hope left for my engine? any advice? thanks
on a serious note, check your oil for radiator fluid or to see if its milky. If its clean thn its probably not a bad head but more than likely something you mentioned above.
