No spark
  • No spark
    99 xj 4.0
    My XJ died on me the other day , it stummbled for 2 mins then it died' and wont restart. Ive replaced the dist, rotor, wires, and CPS. The coil checked out ok when we checked the resistants. There are no blown fuses and it is getting fuel. Any Ideas?
    doing anything strange with the lights on the dash when you put the key in?
      not that I noticed, What do you mean by strange?
        what about the pickup coil in the dist?
            your pickup coil is in the distbutor it send power/spark to the coil
              by strange i mean like, when my computer went bad in my last xj, the check engine light, brake light, etc. wouldnt come on when i turned the key. if i screwed with it for a few minutes by turning the key back and forth, they would all of a sudden light up and thats when it would start. i know this may not be your problem but seeing as you already replaced all of the obvious things that will fail to deliver spark, its an idea. any luck getting it to start/ spark in neutral?
                hmmmmm
                  could still be the coil too. I have seen them a few times go bad only when they are hot. When it is cold, it still has continuity through it, but when it heats up, there is none. Also, are you 100% positive on getting fuel? and im guessing it cranks but just wont start? check/replace the cam sensor?
                    It was the coil, the coil was cracked so it was losing power.
                      Ahh had something similar happen with my 99 sonoma.
