So my engine had a slight knock sound to it for awhile and i just ignored it because it was so slight and i never saw any metal in my oil.... The knock has amplified not horrible but its louder. its coming from the lower back end of the engine but today I crawled under and it almost sounds like it coming more from the bell housing.. maybe it could be the torque converter bolts loose or cracked flywheel? . Is it a common problem for the bolts to come loose. I'm hoping its not rod knock , or some sort of internal problems. The jeep just hit 120k .
any info would be great. Planning on pulling the access cover off the bell-housing to check thous bolts this weekend.
