so i was driving to work the other day and my check engine light came on. I had my friend come over with his code reader and it read large evaporator system leak. Iv look everywhere i can think of and cant find the leak anywhere. I have a 98 XJ with a 4.0 motor. anyone have this problem and can think of anything else to check?
Evap system leak
Evap system leak
Whoever appeals to the law against his fellow man is either a fool or a coward. Whoever cannot take care of himself without that law is both. For a wounded man shall say to his assailant, "If I Live, I will kill you. If I Die, You are Forgiven." Such is the Rule of Honor.Tags: None
how did you check ? just look at things ? things can look fine and throw that code how old is gas cap ?up to 40% off parts from advance auto parts, buy online and pick up at store for free-click here!
i checked the cap it looks fine and also the valve inside the neck. my friend told me a trick he uses to find the leaks, spraying starting fluid on all the lines. it will cause the engine to rev, but no luck. i got underneath and felt around the top of the sending unit but didnt feel any air movement suggesting a leak thereWhoever appeals to the law against his fellow man is either a fool or a coward. Whoever cannot take care of himself without that law is both. For a wounded man shall say to his assailant, "If I Live, I will kill you. If I Die, You are Forgiven." Such is the Rule of Honor.
Dear Campbell,
please edit your sig so the lyrics read correctly.
"...If I live, I will kill you, if I die, you are forgiven..."
Sincerely,
Another Lamb of God fan
As for your question, I would also start with the gas cap, lines, tank, then charcoal canisterOriginally posted by HitItWithSomeSpeeddidnt this thread start with Jon being gay? what happened to that?Originally posted by Lawn Guylandhe's still gay we've just moved on to more important issuesOriginally posted by Zullius Caesari grab dude's junk all the time, doesn't make me gay.
Thank you for the correction i havent even noticed it until now. my badWhoever appeals to the law against his fellow man is either a fool or a coward. Whoever cannot take care of himself without that law is both. For a wounded man shall say to his assailant, "If I Live, I will kill you. If I Die, You are Forgiven." Such is the Rule of Honor.
I was also thinking it might be the charcoal canister, or the LDP itself.Whoever appeals to the law against his fellow man is either a fool or a coward. Whoever cannot take care of himself without that law is both. For a wounded man shall say to his assailant, "If I Live, I will kill you. If I Die, You are Forgiven." Such is the Rule of Honor.
Originally posted by Dcampbell98XJ View Posti checked the cap it looks fine and also the valve inside the neck. my friend told me a trick he uses to find the leaks, spraying starting fluid on all the lines. it will cause the engine to rev, but no luck. i got underneath and felt around the top of the sending unit but didnt feel any air movement suggesting a leak there1993 XJ sport 3.5" rustys 33" MTZ's armored.
