Is / does anyone run skids with a Clayton crossmember? I have a t-case skid now so should I just start welding things to the crossmember or is there a better way around this? Anyone having pics would be nice too. Thanks!
Running Skids with a Clayton Crossmember
don't weld to the crossmember. it is thick enough where you can drill and tap it and just use some countersunk hardware through your tcase skid. a drill and a little bit of time and home fab work and you'll be all set.
want a hand, lemme know buddy
Thanks dudeOriginally posted by JeepBabiiXJ View Postdon't weld to the crossmember. it is thick enough where you can drill and tap it and just use some countersunk hardware through your tcase skid. a drill and a little bit of time and home fab work and you'll be all set.
i did thisOriginally posted by JeepBabiiXJ View Postdon't weld to the crossmember. it is thick enough where you can drill and tap it and just use some countersunk hardware through your tcase skid. a drill and a little bit of time and home fab work and you'll be all set.
