more lift... opinions..
  • more lift... opinions..
    I have a 4.5 lift right now and want a little more. I was thinking getting front coil spacers and shackles for the rear. any suggestions on what would be best? and would there be anything else to upgrade when doing this, other than the brake line....
    1994 ZJ- sold
    1998 XJ-sold
    2011 F-150 ecoboost- daily
    1994 ZJ- 5.5 lift blah blah blah
    - Mike
    what're you looking to gain with the added lift? (other than obviously just more height, lol)
      What size tires do you want to run?
        I'm looking to go around 5.5 to 6'', Kinda of looking for a softer/smoother ride also. I am goin to stick with the 33x12.5 tires..
        1994 ZJ- sold
        1998 XJ-sold
        - Mike
          nothin wrong with a pair of coil spacers and boomerang shackles
            if you dont already have one, be prepared to get an adjustable trac bar for that lift height. you may not need one, who knows. when i went from 4" to 5" on my last rig i had all sorts of new problems, needing an adjustable trac bar was one of them. drop pitman arm might be useful as well. like i said i dont know what you have or dont have, but these things can all be useless if you change your height and nothing happens, or very useful if you change your height and have bad angles and death wobble and driveline vibes. just to name a few things also, longarms might be a good thing to look into also. i had them on my 5" kit and it was a much better ride then when i was short armed with that much lift.
              anything over 4 inch its worth it to get longarms especially if you dont have a good pair of
              control arms.
                control arms.
                shortarms suck with 6.5" the thing flexes like my mustang lol. definitely need longarms to get the most out of it, just way too much control arm angle. if you do go up, get longer shackles and make sure the angle is right so it rides well. Honestly Ive debated trading my 6.5 springs for 4.5 stuff.
                  unless youre looking for more uptravel, or just generally more height at the belly, then higher lifts tend to create more negatives than positives.
                    thats a because you have crustys arms correct? I ran those till I had the money for my longarms.
