A SOA On a 95 Yj what do i need to change if anything. Driveshaft, shocks i know, alignment im not sure i wanna get some info before i dive head in to a project i have no idea about lol but im just trying to get a SOA because im empty pocketed right now.... no money so trying to go cheap and dirty thanks sis
SOA on a 95 YJ
haha this can be easy , and hard at the same time
i replyed in the for sale section about the shocks
depends, on some spring overs you take your u-bolt plate and move it to the top of your leaf and axle... the plate also has your shock mount on it so you can use the same shock. also for the rear i recommend moving your axle side shock mounts flush with your axle tube. this will also allow you to run the same shock (within an inch or so)and give you clearance at the same time
- stock springs will work but will be soft, you SHOULD to find another set of stock leafs to take apart and add leafs to your stockers
- going to need an anti-wrap bar in the rear or you going to blow driveshafts/u-joints/yokes
- new shackles cuz the stock ones crack around the bolts cuz SOA flexes well (ask me how i know)
- your going to need high steer in the front to clear the leafs, you can get a kit from teraflex or get a d44 and put high steer arms on it
- moving perches and shock mounts, adjusting for pinion agle and caster
- bigger tires = more stress and need of a re-gear
the cheap way, is finding a hpd30 and a ford 8.8 with matching gears
the better way is getting a set of waggy axles, gearing and locking them
the best way is to just get full width ford d60's and calling it good
well i hope this help to get you started, if you have any questions give me a shout, i had a sprung over yj at one point and can give you some tips. - Dana"when I'm riding my motorcycle,I'm glad to be alive...when I stop riding my motorcycle,I'm glad to be alive"
in all honesty if this is your first time lifting a vehicle and your not looking to spend a lot of money i would do other things first.
what gears do you have? if you dont have 3.07's get a 3" lift and run some 33's
my roomate just got a 3" lift for his yj off craigslist for $300 and all you have to do is move your break lines down and maybe get a pitman arm ($30)"when I'm riding my motorcycle,I'm glad to be alive...when I stop riding my motorcycle,I'm glad to be alive"
Originally posted by grundlepunch View Postin all honesty if this is your first time lifting a vehicle and your not looking to spend a lot of money i would do other things first.
my roomate just got a 3" lift for his yj off craigslist for $300 and all you have to do is move your break lines down and maybe get a pitman arm ($30)95 Yj 4.0, Flowmaster 40 series exhaust, Blue Hids and Yellow Fog Lights, K&N air filter, 2" Boomarang shackles, and sway bar and track bar removal.
SOA is a big job but i guarantee you will be happy with it. you can get a soa kit online and you just need to have someone weld the spring perches for you. i did a bolt on lift and i regret it terribly not because it was a waste of money. if you do decide your going to do a kit i'll sell you all 4 of my full leaf packs for the price of a set of waggy front packs. my packs cost $750 brand new and there exactly 1 year old in 2 weeks, and there in great condition. i also have track bar brackets and u-bolts and a t-case 1" lowering kit for free with the packs the only things you'd have to buy would be brake lines1991 YJ, 1 tons, locked, lots o armor, stretched, cage
