Hi, i have been wanting to do this swap for a long time, i have been running 33's on my dana 35 and i worry everyday that it will break. So now is the time. What will be a direct bolt up to my jeep, 1990 jeep cherokee 4.0 limited. Thanks guys, i have limited funds so a direct bolt up is necessary.
1990 Dana 35 swap to 8.25
The acual swapping of the axles will be the easy part, the axle will literally bolt in place. Just make sure whatever axle your using has good brakes. Make sure you have a good set of brakeline tools because you will have to take the drums apart to take the e-brake cables off. The cables, drive shaft, and brake line from the axle will all work.98 Cherokee, D30/8.25 w/4.56s locked F/R -- 3 link front IRO springs rear with shackle relocation, one ton steering w/heims, hybrid cage under contruction, 33'' KM2's
THankyou all, i think i just found an axle, its a 27 spline. What do you all think about running 33 on it? stock gears of course. I know the pick up is bad, but i run 33s on my d35. How much better is the 29 spline really?Lift: 4.5" RC
Tires: 33" BFG A/T's
Misc: Hamerred Tan Paint, Homemade Roof Rack, Bumpers and Half Doors.
