so my dana 30 hubs don't last that long, i put two new ones in around june and they are wasted already. i'm using the good autozone ones. yes they are under warranty, but i don't feeli like ripping my jeep apart every 5 months. does anycompany make a better wheel bearing that is a little more heavy duty?
wheel bearings
Autozone's are timken.
http://www.autozone.com/autozone/par...=17405_3214_0_
I use the NTP ones from advance and have never had an issue with them. They're made by federal mogul, everyone claims that timken's are better quality, but i've used national and the timken ones in my D44. And to me they are pretty much the same, last the same amount of time.
Ohh well, you could have just gotten a bad one.
you could convert your 30 to hubs though, waayyyy stronger than unit bearings.
solid axle/Spyntec makes a dookin kit:
http://www.solidaxle.com/productcart...&idcategory=17
the only shitty part is that it changes your bolt pattern to 5x5.5Last edited by Zullock Holmes; 12-05-2010, 10:20 PM.No worries, I'm not actually back, I'm just reminiscing about the old days.
knuckles, hubs, 30 spl outers, IMO if you're running 37's on a dana 30 its worth it
I personally think its a little rediculous too, but if you got the money and feel like spending it on a dana 30 then, its deff quite the upgrade.No worries, I'm not actually back, I'm just reminiscing about the old days.
This is the cheapest place I found for hub bearings
http://www.hubbearing.com/
And little axles don't last long with big tires and hard wheeling.
if you really want stronger Unit bearings then you need a D60.
~JustinRCrocs #123 Brown CJ-5
