Bought a new heating core today since the air is semi warm always. Anybody have any tips or suggestions on replacing one in an 01 tj? Anybody do this themselves yet?
Heating Core Replacement
If Its like an XJ Im pretty sure you do... its not as bad as it sounds its probably about 4 hours worth of work.89XJ Pioneer Edition 3.5" 33s ravines 4:10s 8.8- parted but not forgotten
Is it leaking.
A good trick is to just reverse the flow (swap the too lines) usually clears it out. Worked for me a bunch of times.
then return the heater core.
Most cars you need to undo the A/C.RCrocs #123 Brown CJ-5
Originally posted by bangarang View PostBought a new heating core today since the air is semi warm always. Anybody have any tips or suggestions on replacing one in an 01 tj? Anybody do this themselves yet?
(you see what I did there?)"Watching you work on your Jeep is like watching a doctor operate on a cadaver...
If i flush the heater core then do I even have to worry about getting the refrigerant purged from the air conditioner first? The cores not leaking that i can tell. Its a bit cold when its -10 in the morning.Last edited by bangarang; 12-03-2010, 03:24 PM.1981 CJ8 - old & dumb
2001 TJ Sport - DD
Originally posted by bangarang View PostIf i flush the heater core then do I even have to worry about getting the refrigerant purged from the air conditioner first? The cores not leaking that i can tell. Its a bit cold when I'm being a little bitch in the morning."Watching you work on your Jeep is like watching a doctor operate on a cadaver...
No you dont have to worry about purging the refigereant because you arent opening the ac system.
http://answers.yahoo.com/question/in...9000334AAAok4v2000 XJ with goodies soon to be in pieces
