uh oh..
  • uh oh..
    So I fixed my belt squeal but my jeep has developed a really bad sputtering and popping. Its bogging out really bad and there seems to be alot of air in the fuel lines. I couldn't find any holes or anything but its running like total shit. It barely stays running and every time I give it gas it just bogs out and sputters and pops its like the timing is off or something. Idk what's up with it. Any suggestions? Thanks.
    how can you tell theres air in the fuel line ? what did you change recently ? hit any wires/connectors ? what year vehicle ?
      There's a ton of air coming out of the check valve on the fuel rail when I press it in. I went wheeling and the jeep got a little wet but nothing more than normal, there's no water in the engine or fuel or anything. Its a 96 xj auto. When I push in the thing on the fuel rail, fuel and air comes out, like alot more pressure than there should be. Also when I do this, It starts and runs ok, but then after a few minutes it goes to shit and when I give it gas after that it just completely bogs out.
        mine did this when my ballast resistor shit the bed
          Is that like the vacuum bottle that's in the bumper or something else? Now that you said that it actually seems like a vacuum problem. When I hit the gas its like sucking too much air or something like that. Its definately a fuel/air problem.
            no, on the drivers side fender, there is a little shale type thing with two connectors, i found out it was my problem by disconnecting the two, and using a thick ass wire to complete the circuit between them.
              I just checked online and my 96 doesn't have one I don't think.. I could be wrong but ill check just to be sure.
                How bad was your xj running? Mine wont even run without me purging the check valve on the fuel rail. Then once it starts, its ok for a few and then if I give it gas it wont rev at all it starts bogging and sputtering and popping really bad. Was your problem similar to this? Like its completely not driveable.
                  yep, mine would start, then constantly loose fuel pressure, ended up buying a fuel pump that wasn't needed.
                    try cycling the key a few times, if it starts easier, than you probably have a bad fuel pressure regulator
                      Yeah my fuel pump is pushing plenty of fuel up into the rail. It turns on as it should with every turn of the key. I'm going to have to see if my 96 has the resistor or not. What gauge wire would you say you used to jump it?
                        probably around 10 guage'ish don't do this to often or let it run that long like that cause it will eventually cause a fire
                          did you check your distrivutor cap?
                          94 xj 4.0L, AW4, 242
                          3" rusty's lift, 33x12.5 bfg km2's, custom front bumper
                            Yep cap and rotor are good.
                              Whats the fuel pressure at the rail when you can get it to run? What is the primed pressure? Ever change the fuel filter? Check spark in all cylinders?
