So i recently got a xj, lifted it 2in and pulled the sway bars.then the story goes like this, every time the wheel is turned to the left and I hit a bump, the jeep goes into the wobble. I'm pretty sure an adj. trac bar or trac bar drop mount will cure it? True or false?
another death wobble question
how are the bolts/bushings on the track bar, is the bracket on the body tight, and if you just added 2 inches of lift, you need to make up for that with the trackbar adjusment
http://sisoffroad.com/forums/showthr...?p=911#post911God made the world in seven days, on the 7th day, he made the Le Car
