another death wobble question
  • another death wobble question
    So i recently got a xj, lifted it 2in and pulled the sway bars.then the story goes like this, every time the wheel is turned to the left and I hit a bump, the jeep goes into the wobble. I'm pretty sure an adj. trac bar or trac bar drop mount will cure it? True or false?
    4x4 Station Wagon...
    just trying to narrow the problem down right the first time.
      how are the bolts/bushings on the track bar, is the bracket on the body tight, and if you just added 2 inches of lift, you need to make up for that with the trackbar adjusment
      http://sisoffroad.com/forums/showthr...?p=911#post911
        does anyone make just a drop bracket?
          i run the krustys drop bracket.
            Skyjacker makes one.
              i used to have this and it made my drag link and trac bar have different angles. i wouldn't recommend it
              94 xj 4.0L, AW4, 242
                im not seeing it on the site. do you have the link?
                  http://rustysoffroad.com/mm5/merchan..._Code=SUS_TRAC
                    so its been about a week with no DW... since I dropped the Trac bar
                    today i had a noticeably low front left tire, after i put air in it and got it level and back to normal. I had the wobble then? So I let the air back out... and no wobble....
                    any ideas?
                      are your lugs tight? if not the wheel might move around a bit more when it's inflated more
                        something has to be loose. the low tire is probably absorbing the wobble. could be a bad bearing being loose or tie rod end. hows the alignment
                          balljoint or unit hub
                            roger that..
                              When i lifted my XJ i had a death wobble and after getting an alignment it fixed the problem. the toe was off causing it to death wobble. maybe the same problem.
                              01 tj
