The famous engine knock
  • The famous engine knock
    My jeep is now going on 225k miles. Has never let me down and has never Needed water pump or anything, although i may do one soon for ease of mind sake. However, with the weather getting colder the valve knock is getting worse, it quiets down at a higher rpm and it also gets quieter at a higher temp. Ive been driving it with this knock for 30k miles and im positive its not a rod knock.
    Is there anything i can do to make it not sound like a diesel?
    Thanks- pat
    thicker oil might help
      Did you pinpoint exactly where the knock is coming from? My cherokee has 210k on it and it makes the same exact knocking noise, it sounds like a diesel at idle. It gets great oil pressure and runs good for 210k. It had that noise for like 3 yrs. And like you, never had any driveablity issues at all. So one day I ended up tracking the noise down near the bellhousing and I found the flywheel had a hairline crack in it creating that noise. Its a common problem for the 4 litres with high mileage. I heard that from a mechanic from a mopar dealership.
      93 Cherokee
      Rough Country Kit
      4.5 inch front coils
      5 inch rear
      34x 10.5 in TSLs on rock crawler wheels
      sway bar discos
      d30 front d44 rear
      Rusty's pre runner bumper
      rocker rot included
      78 Malibu (sleeper)
      95 Tahoe
        Sounds like a collapsed lifter.
