1 Ton Issue
  • 1 Ton Issue
    when turning the wheel left and right the bottom drag link end joint rotates forward and backward causing about an 8th turn of play in the steering wheel, other than that everything is fine, any ideas?
    1945 Willys-Overland CJ2A
    Normal. Move along....nothing to see here...
      its tie rod roll
      hence why i deep sixed inverted T steering
      get poly spacers for your ends and have a ball
        true fixes? get crossover steering.
        band aids? poly or HDPE spacers on the TREs.
          alright so it is normal then, thats all i needed to hear, just didnt want it fallin apart on me when i had the kid in the truck. where do i get said spacers just to make it a little cleaner?
            less lift will also solve this issue
            or mount it otk
            or both
            or get the band aid spacers
              get spacers where
                JCR
                  thanks
                    This is exactly why I'm having my steering custom made from hiem joints- no slop.
                    2006 Rubicon - high rock bumper, warn 9.5ti, and lots of stockness....for now...
                      ohhh yea zach... lol thats why mine dont do that, i have a lil polly space that came wit my kit under the pass side TRE it stops it from moveing like that
                      #becauseJoeNitro
                        My 1 ton ends do that too. I have the same setup on my YJ. The spacers are supposed to work really well. The only reason I didn't switch to heims is because I keep bending the 1 ton tie rod ends and they are easy to get at any parts store.
                          spacers. you can buy a sheet of hdpe and cut out your own spacers.
                            already ordered, 10 bucks shipped, no biggie
