heater/fan doesnt work
  • heater/fan doesnt work
    According to this: http://www.lunghd.com/Tech_Articles/...tification.htm
    the 25 fuse in the kick panel is the one that controls the blower/heater. My switches turn on the heat, but it doesnt blow anything. The fuse isnt bad after visual inspection.
    What do I need to look at?
    Blower motor resistor???
    2013 F150 fx4 (Tow Pig/DD)
    • 5.0 with the 3.73 option
    2003 TJ Rubicon
    • 4.0/42rle/np241or
    • 5.13's
    • 33” BFG KO2s
      X2
        Or the actual blower motor itself. My father already had to replace his in the Neilmobile.
          Yeah, first check if there is power at the motor. If there is, thats yo bitch.
            thanks guys. the resistor is easy pie. where da motor at?
              http://www.lunghd.com/Tech_Articles/...ower_Motor.htm
                or resister
                http://www.cherokeetalk.com/forum/f6...acement-11133/
                  Usually if a resistor is bad it'll look burned out. Either way, do a continuity check over the resistor just to be sure
                    motor is behind the dash....however you can probably access that shit from looking up under there. you can see the blower motor from in the engine bay too i believe.
                      im pretty sure you just voluntold yourself to come over with a tester sometime
                      cool deal. thanks
                        Mine did this and it turned out there was a clog in the core. Did you try flushing it?
                          i havent tried anything yet
                            Depending on how often you flush the coolant, might be a good idea to do so anyway for giggles and ha-has.
                              WHY DO I GET VOLUNTOLD FOR EVERYTHING!!!!!
