is it overshimmed?
vibes what to do
checked my u joints and u bolts both tight and my u joints are good they are spicer 760s and still nice. my tire pressures were all over the board driver rear 6 right rear 20 driver front 19 pass front 30 that might do something. and my shocks are almost at full travel cause they are shitty skyjackersDizz dizz go sleep sleep
Hi Dizzy, Your easiest solution would be to place the transfer case. You only need about 1 inch spacers and longer bolts. I think there are only four screws that hold the transfer case assembly on the truck. Place a jack under the mounting bracket and remove the screws. Then slowly lower the ride until you can install the spacers and new bolts. If you have any questions, feel free to join my jeep.
'96+ XJs are known to have pretty bad vibes with anything over 3" due to the different style T-case output. A T-case drop is usually good up till 3", and past that most people need a SYE. Vibes are also more common with the 8.25 axle, but it depends a lot on the XJ. My friend lifted his 2000 5" with the 8.25 and NP242 and was fine with just a T-case drop. His brother lifted his '96 3" and even with a T-case drop had more vibes than even his GF could handle.
-Josh
I wanna know how you didnt notice that your driver rear was only 6psiOriginally posted by dizzy View Postchecked my u joints and u bolts both tight and my u joints are good they are spicer 760s and still nice. my tire pressures were all over the board driver rear 6 right rear 20 driver front 19 pass front 30 that might do something. and my shocks are almost at full travel cause they are shitty skyjackers
just suck it up and get an SYE and actually fix the problem
i don't know my tires never look flat till they are unless i'm actually crawling and i actually installed sye on monday vibes gone drives like a stock jeep again minus the tire howl and roughness lol so nothing like a stocker hahahaOriginally posted by CumminsJeep View PostI wanna know how you didnt notice that your driver rear was only 6psi
just suck it up and get an SYE and actually fix the problemDizz dizz go sleep sleep
You will run around in circles trying to find ways to make it go away trust me, its well worth dropping a few bucks on an sye, then just use a stock xj front shaft for the rear..Plus those vibes have been known to hurt the output on the t-case...Not sating it will happen to you but i have seen it happen.98 Cherokee, D30/8.25 w/4.56s locked F/R -- 3 link front IRO springs rear with shackle relocation, one ton steering w/heims, hybrid cage under contruction, 33'' KM2's
