http://pirate4x4.com/forum/showthrea...=914583&page=9
Just found this thread looks interesting.
For the cliff notes:
You can install D50 gears in a HP D44 housing and you can install D70 gears in a HP D60 housing.
They both sets have the same Hypoid offset, don't know about the pinion depth.
From the pinion depth tool instructions.
http://www.ringpinion.com/Content/Ho...etting_Kit.pdf
MHD (Master housing depth so bottom of the pinion)
D44 4.312
D50 4.616
D60 5.000
D70 5.375
So I don't know if they are using different bearings.
The housing needs grinding to fit the larger gears.
I'm not sure about the depth I think it said something about different bearing.
He did say the D70 gears on a D60 carrier need to be redrilled and a spacer ring to center the gear.
I did not find anything about the D50 gears on a D44 only that you need the high speed carrier break because the D50 doesn't use a carrier break.
I'll need to do some more investigation but looks cool.
I have a D50 and a HP44 in my garage right now I'll get some measurements when I get some free time.
I just wanted to know if anyone has done this before or if you know someone who has?
~Justin
D44 4.312
D50 4.616
D60 5.000
D70 5.375
~Justin
