For an update.
Kind of like not having a working Xbox I get more work done.
Anyways.
I used my the long probe along with the magnet for the pinion head so the measurements are not the Pinion depth but as long as I did the same for both it doesn't matter I'm just looking for the difference. The difference came out to .319 so I need to recess the D50 pinion .319" further into the housing for it to mate up correctly to its ring gear.
This does not include removing shims.
I measured the Pinion Head Depth of the D50 pinion head in a D50 housing.
.875"
Then I swapped the bearings see below and measured the D50 pinion head in a D44 housing. And it was .556 for a difference of .319.
The D50 is a +2 and the D44 is a +3
Now the D50 is shimmed under the pinion bearing and the D44 is shimmed under the race. So I removed the Pinion shim when I swapped bearings plus I installed the Oil slinger. The master Head depth Difference from above is .304 close I don't know if oil slinger baffels or different bearings made a difference.
50 left, 44 right
Removing bearings
50 left, 44 right
D44 bearings installed on D50 pinion (Left)
To believe it or not. The D44 has larger OD bearings for both the Pinion Main bearings and the carrier bearing I did not compare Pinion preload bearings did not take it out of the D50 yet.
Also Compared the Seals and they all look to have the same OD I didn't do the best job removing them but they look straight enough to compare.
D44 (79 F250) D50 (2000 F250) D60 (89 F350)
D44 seal on D50
D44 Seal on D60
Anyways.
.875"
50 left, 44 right
Removing bearings
50 left, 44 right
D44 seal on D50
D44 Seal on D60
