tire tubes and sizes
  • tire tubes and sizes
    so, i have a set of 31" general grabber at2 tires that are like brand new but when i bought them on rims, i didnt know there was tubes in them and the sidewalls had been stabbed with and awle/screwdriver. foolishly, we cut the tubes out when we took the tires off the rims. does anyone know A: where i can buy new tire tubes and B: what size tube to use for a 31x10.5-15? i looked at a bunch of tubes but i have no idea how to read the sizes.
    those tires are between $100 and $120 dollars a piece. I wouldn't run tires with tubes, I'd grab some new tires but that's just me, and I understand that I didn't answer your question.
      well the tube size will relate to the tire size. and also, i wouldnt run tubes in them if you can avoid it. go to napa i know they have tubes. they will be able to help you out
        ill try napa, thanks. What's so bad about tubes though? I know people who've ran them for years with no problem. These are just going on my s10 as winter tires bc they're studded. They won't be aired down for trail use at all
          Just called napa, they don't have anything big enough for 31's
            why not just go to a truck stop and get them volcanized...
              Originally posted by clean4drxj View Post
              volcanized...
              i keep hearing of this....explain
                Summit racing has tubes for drag racers up to 33" but they are like $80-100
                You can try quad tubes I have the part number at home for the largest quad tube that's what we use in the inner air locks might blow up large enough. They are like $25
                  I went on ebay and contacted the seller of this item: http://cgi.ebay.com/ws/eBayISAPI.dll...:X:RTQ:US:1123
                  He said tubes for my 35's would be 29.05 + shipping
                  2 Broncos are better than 1
                    thanks guys, found some from chicago tire for 30 bucks a piece and they fit 31-33" tires. What is vulcanizing though, and how is it good for tires with tubes??
                      Post the part number for the tubes so the rest of us can benefit.
                      vulcanizing is melting the rubber back together basically 2 hot plates spring loaded together takes a few hours but you can legaly fix side walls with it they use it a lot for large trucks where the tires are really expensive.
                      This is if you didn't cut the coards it cost around $75 to get done and only a few places do it.
                      The machine is around a grand. have looked to buy one, figure once I start rock racing it might be a worth while investment.
                      ~Justin
                        Can they do it on regular LT tires like a BFG Mud terrain?
                          here ya go fellas
                          http://www.trucktireretreading.com/s...bes/Categories
                            go down to don stevens tire in southington, ct. i used to work there, the tubes are pretty cheap (thats if your still looking to go that route)
                            2000 Jeep Cherokee Sport, 4.0L I6, stock for now
