AW4 version compatibility
  • AW4 version compatibility
    Need a new planetary and clutch assembly buddy has one from an 89 that looks the same, rather not install the tranny with wrong internals. What years can I swap parts with, never had an auto before so not up to speed.
    TIA
    Doug
    for a 2000 xj sport
    are there any websites that sell individual internal tranny parts?
    1992 xj Briarwood
    Welded front and rear
    13' LED roof lights
    Disco ball
    Truck nuts
    Spinners
    you are limited to using a 99-early 01 aw4 if you want it to be plug and play.
    if you want to play around with tcu's and wiring you can make a 91-98 work...
    don't bother with anything older than a 91. wrong output spline count, renix wiring, and probably other things.
      I just needed that oil pump, took one out of an 89, everything measured up right and it popped right in.....just have to get the gears back in that fell out
      1992 xj Briarwood
      13' LED roof lights
      Disco ball
      Truck nuts
      Spinners
