I need to start looking for some new wheels for the 60s, not sure what size wheels I can run though, there the 78/79 f250 60s. I was hoping I can run 15s but not sure with the brakes.
what size rims for dana 60s
I run Blackbird Customs brackets on my Ford 60 front. They use GM 3/4 calipers and rotors. I have the same calipers and rotors on my rear 14 bolt. Blackbird markets the kit to people who want to run 15" wheels on a Dana 60. I run 16s.1950 Willys Trail Rig
H2's are 17s I do believe. Shouldn't have any problem with those.1950 Willys Trail Rig
would these work, but 6.5 inches wide, seems to narrow. i want something i can do beadlocks on eventually.
http://cgi.ebay.com/ebaymotors/SET-4...Q5fAccessories
I have a set of steel 16.5x10 8 lug 4 for $100 if your interested.
I run 16" steel rims on my CJ with Ford D60sRCrocs #123 Brown CJ-5
Originally posted by Pete View Post16.5 hmmm, I would like 16 or 17, seems like an easier size to find. They just black steeliesRCrocs #123 Brown CJ-5
I run 16 x 9s with the creeps, stock front calipers. You will not get 15s on stock calipers unless the rims have 2" of backspacing, but then you're the wide-J. 17s are ideal cause everyone makes tires that size.
H2's are sweet, only way to bead lock is stauns though and they are about 600 bucks for a set.
