Well to keep up with my buddies locked rigs Ive been thinking of welding my 8.8 diff however its a limited slip, is welding this any different then welding up a standard open diff? I would just buy an aussie but then I'd have to change the carrier, Bank accounts deffinatly not going to allow for that right now.
Welding LSD diff
just realized i posted this in the wrong spot.... if someone wants to move it to tech that'd be cool.89XJ Pioneer Edition 3.5" 33s ravines 4:10s 8.8- parted but not forgotten
95XJ tons 3 link 36s 5:38s
97 F-250HD 7.3 Turbo Diesel
"Shut up and Wheel"
Originally posted by WAD357 View PostWell to keep up with my buddies locked rigs Ive been thinking of welding my 8.8 diff however its a limited slip, is welding this any different then welding up a standard open diff? I would just buy an aussie but then I'd have to change the carrier, Bank accounts deffinatly not going to allow for that right now.1950 Willys Trail Rig
I dont think you can weld a conventional LSD but the ford trackloc is wierd it still has spiders heres a pic let me know what you think
"Shut up and Wheel"
Originally posted by WAD357 View PostI dont think you can weld a conventional LSD but the ford trackloc is wierd it still has spiders heres a pic let me know what you think
I thought it could be... Any suggestions on welding a plate in or just weld the gears? and should i weld gear to gear or gear to housing or both? not to be a PITA just making sure im doing this right and am not gunna warp the carrier or some bs89XJ Pioneer Edition 3.5" 33s ravines 4:10s 8.8- parted but not forgotten
"Shut up and Wheel"
I always go gear to gear and gear to case. In this case you might need to put some flat stock from the side gears to the case. Then just weld gear to gear and the spiders to the case. With every 8.8 I've done, you have to make sure you can still get the cross pin out so you can get the c clips out, pretty important to remember!1950 Willys Trail Rig
Pulled the carrier and found half the clutches in the bottom of the housing.... welded it up and slapped it all back together gotta love hearin the tires squeal around corners89XJ Pioneer Edition 3.5" 33s ravines 4:10s 8.8- parted but not forgotten
"Shut up and Wheel"
Nice dude, what did you weld it with? I usually spend a good hour or two cleaning it after welding to get all the spatter and slag out. Then I like to change the oil shortly after, just in case anything stayed in there. You don't want that shit to tear up your bearings or gears.1950 Willys Trail Rig
Originally posted by Burton58 View Posti knew that damn thing was open
Originally posted by OWEN View PostNice dude, what did you weld it with? I usually spend a good hour or two cleaning it after welding to get all the spatter and slag out. Then I like to change the oil shortly after, just in case anything stayed in there. You don't want that shit to tear up your bearings or gears.89XJ Pioneer Edition 3.5" 33s ravines 4:10s 8.8- parted but not forgotten
"Shut up and Wheel"
